[GRASS-user] interactive multiple selection
Vincent Bain bain at toraval.fr
Wed Jan 21 06:21:57 EST 2009
Thank you Markus,
I tried several methods like d.extract, or
d.where | v.what map=zonpi > test and extracting cat values from the
test file. Now I am wondering if it is worth (let's better say realistic
given my skills) to try and write a custom module, inspired from
v.digatt.
As I already had a little experience in perl and wxwidget (frontend for
data capture in postgres database) I would appreciate later on to
involve in writing a python add-on, but like everyone, my principal
ennemy is the lack of time !
Beside data storing, treatment, analysis, I think it would be great to
improve data *production* tools, and it's what I would like to
contribute.
Vincent.
Le mercredi 21 janvier 2009 à 09:32 +0100, Markus Neteler a écrit :
> On Wed, Jan 21, 2009 at 9:25 AM, Vincent Bain <bain at toraval.fr> wrote:
> > Hello,
> > considering a vector map, do you know a simple way to perform multiple
> > selections (e.g. highlighting a set of polygons) interactively either on
> > the display (tcltk or wxpython) or through a X monitor ? the aim in the
> > end is to update database records on the basis of a cat list.
> > I tried the addon v.digatt but I can't run it correctly (I think a
> > possible reason is my vector is linked to a pg db driver, and the module
> > was tested only with dbf driver).
> Coudl this help?
> d.extract help
> Description:
>  Selects and extracts vectors with mouse into new vector map.
> It's not perfect but maybe a starter.
> Markus
