[GRASS-user] Character encoding problem
Wed Jan 21 09:57:27 EST 2009
Markus Neteler wrote:
> > [1] Provided that GRASS was built to use iconv(); this is
> > autodetected. Otherwise, text is treated as ISO-8859-1.
> Could we issue a warning in this case that iconv support is
> missing? To give the user a hint?
Under what circumstances? We probably don't want to issue a warning if
the encoding isn't being set explicitly by the user, or if the
encoding is set to ISO-8859-1 or US-ASCII (and a string comparison
won't handle aliases).
