[GRASS-user] problems with v.edit
chiaraercoli at tiscali.it
Thu Jan 22 07:12:13 EST 2009
----Messaggio originale----
Da: landa.martin at gmail.com
Data: 20/01/2009 19.20
A: "chiaraercoli at tiscali.it"<chiaraercoli at tiscali.it>
Cc: <grass-user at lists.osgeo.org>
Ogg: Re: [GRASS-user] problems with v.edit
2009/1/20 chiaraercoli at tiscali.it <chiaraercoli at tiscali.it>:
> I have a problem with v-edit.
> I have to break a vector line
> into two parts near a point. I gave this command:
> v.edit map=ret_125
> layer=1 type=line tool=break thresh=$ris_edit coords=$x,$y snap=no
> where " $ris_edit " depends on the resolution of the DEM raster
map,
> "$x" and "$y" are the coordinates of the point.
are you sure that threshold value is enough to select vector feature
which you want to break?
v.edit map=ret_125 tool=select thresh=$ris_edit coords=$x,$y
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
I send you the line, ret_125, and the point, punto_minimo.
Thanks for all,
Chiara .
_______________________________________________________________
Attiva Tiscali Tutto Incluso: telefoni e navighi senza limiti A SOLI €10 AL MESE FINO ALL?ESTATE. Attiva entro il 22/01/09!
http://abbonati.tiscali.it/promo/tuttoincluso/
Name: punto_minimo at thresh12000.shp
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090122/75387069/punto_minimothresh12000.obj
PROJCS["WGS_1984_UTM_Zone_19S",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-69],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",10000000],UNIT["Meter",1]]
Name: ret_125 at thresh12000.dbf
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090122/75387069/ret_125thresh12000.obj
Name: ret_125 at thresh12000.shx
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090122/75387069/ret_125thresh12000-0001.obj
Name: ret_125 at thresh12000.shp
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090122/75387069/ret_125thresh12000-0002.obj
Name: punto_minimo at thresh12000.dbf
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090122/75387069/punto_minimothresh12000-0001.obj
Name: punto_minimo at thresh12000.shx
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090122/75387069/punto_minimothresh12000-0002.obj
