[GRASS-user] georectify tool in wxGUI
Vincent Bain
bain at toraval.fr
Thu Jan 22 13:52:28 EST 2009
trying to use the georectify tool through the wxGUI, the rms error for
each point did not display in the array, and the rectify operation
finally failed.
The returned message was :
File "/usr/local/grass-6.4.0svn/etc/wxpython/gui_modules/g
eorect.py", line 969, in OnRMS
self.RMSError(self.xygroup,self.gr_order)
eorect.py", line 1105, in RMSError
self.SaveGCPs(None)
eorect.py", line 895, in SaveGCPs
self.parent.goutput.WriteLog(_('POINTS file <%s> saved') %
self.file['points'])
output.py", line 235, in WriteLog
line += diff * ' '
UnboundLocalError
local variable 'diff' referenced before assignment
(Running the same rectification from tcltk interface works perfectly)
Has this problem already been raised ?
Vincent
