[GRASS-user] Aspect direction in r.slope.aspect
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Mon Jan 26 21:45:18 EST 2009
On Sun, 2009-01-25 at 12:40 -0800, Hamish wrote:
> Doc Robinson wrote:
> > 4. What then about r.param.scale? Output is in the 0 +/- 180 range rather
> > than 0-360.
Hamish:
> I have added more metadata output to r.param.scale in trunk and develbranch6.
> testing welcome.
Hamish, I've just had a quick-run.
Regards, Nikos
> | Layer: test_latest_r.param.scale Date: Tue Jan 27 03:42:35 2009 |
> | Mapset: nik Login of Creator: nik |
> | Location: hgrs87 |
> | DataBase: /geo/grassdb/peloponnese |
> | Title: DEM terrain parameter: Direction of maximum gradient ( test_late |
> | Timestamp: none |
> | Type of Map: raster Number of Categories: 255 |
> | Data Type: DCELL |
> | Data Units: degrees Vertical datum: |
> | Rows: 1337 |
> | Columns: 840 |
> | Total Cells: 1123080 |
> | Projection: Transverse Mercator |
> | N: 4530000 S: 3861500 Res: 500 |
> | E: 557500 W: 137500 Res: 500 |
> | Range of data: min = -179.944962 max = 180.000002 |
> | Data Source: |
> | srtm3 at PERMANENT |
> | Data Description: |
> | generated by r.param.scale |
> | Comments: |
> | Flow direction (aspect): W=0, E=180, N=+90, S=-90 degrees |
> | r.param.scale input="srtm3 at PERMANENT" output="test_latest_r.param.sc\ |
> | ale" s_tol=1.0 c_tol=0.0001 size=3 param="aspect" exp=0.0 zscale=1.0 |
