[GRASS-user] g.region, problem with projection
Andreas Neumann a.neumann at carto.net
Tue Jan 27 14:22:10 EST 2009
Hi all,
I have problems with setting g.region - I always get an error message
like the follows:
region for current mapset <projection field missing>
However, I defined the projection globally in the PERMANENT mapset of my
location.
I am using grass 6.4 on the Mac with the frameworks of William
Kyngesbury. The PROJ framework is also installed and I can browse the
list with epsg codes.
Anyone knows what could be wrong - why g.region is complaining about the
missing projection field?
Thanks a lot,
Andreas
Andreas Neumann
Switzerland
Email: a.neumann at carto.net
Web: http://www.carto.net/neumann/
SVG Examples: http://www.carto.net/papers/svg/samples/
SVG.Open: http://www.svgopen.org/
