[GRASS-user] Looking for a tool to allocate cells to its nearest neighbor
Lluís Vicens lluis at sigte.udg.es
Wed Jan 28 10:30:00 EST 2009
I've been searching a tool like 'ALLOCATE'(Idrisi) in GRASS, but I can't
find it. There is any kind of tool like that in GRASS? Which is the best
way to perform this kind of operation?
Allocate in Idrisi:
> ALLOCATE performs spatial allocation based on a distance or
> cost-distance image derived from DISTANCE, COST,
> VARCOST or DISPERSE. For example, if the distance surface were
> calculated from a set of health centers, ALLO-
> CATE could be used to assign each cell to its nearest health center.
> The final result of ALLOCATE would be an image
> with identifiers indicating to which health center each cell is
> assigned. The result from ALLOCATE is identical to that of
> THIESSEN where simple Euclidean distance is used. However, if cost
> distance is used, the result may be quite different.
Thanks in advance!
Lluís
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090128/8b500d54/attachment.html
