[GRASS-user] Terrain Modeling on Small Areas
Frank Aragona
frank at agroinnovations.com
Wed Jan 28 14:08:33 EST 2009
What I'd really like to know, actually, is how to do terrain modelling
and waterflow analysis on a small area. I have a .csv file with xyz
coordinates. My approach has been:
1. Import this using v.in.ascii -z input=C:some_file.csv
output=vector_xyz format=point fs=, skip=0 x=2 y=3 z=5 cat=1
2. Create an interpolated raster surface with v.surf.idw from the
imported vector map.
3. R.contour for a contour map from the output of v.surf.idw
4. R.flow to determine flow lines of water on the map surface
Do you all think this is a good approach? My area is very small, about
10 acres. I'm not quite sure about the quality of my outputs. If
somebody is willing to give some tips here, would much appreciate it.
Frank Aragona
