[GRASS-user] compile grass gdal from svn
Paolo Craveri
pcraveri at gmail.com
Thu Jan 29 14:11:58 EST 2009
Hi to all
I have just build gdal and grass (6.5) from their respective svn sources.
When I start grass, I get this error:
WARNING: Digitization tool is disabled (libgdal1.5.0.so.1: cannot open
shared object file: No such file or directory). Detailed information
in README file.
File "/usr/local/grass-6.5.svn/etc/wxpython/wxgui.py", line 1642, in <module>
sys.exit(main())
File "/usr/local/grass-6.5.svn/etc/wxpython/wxgui.py", line 1635, in main
app = GMApp(workspaceFile)
File "/usr/local/grass-6.5.svn/etc/wxpython/wxgui.py", line 1557, in __init__
wx.App.__init__(self, False)
File "/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode/wx/_core.py",
line 7912, in __init__
self._BootstrapApp()
line 7487, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File "/usr/local/grass-6.5.svn/etc/wxpython/wxgui.py", line 1573, in OnInit
workspace = self.workspaceFile)
File "/usr/local/grass-6.5.svn/etc/wxpython/wxgui.py", line 175, in __init__
self.NewDisplay(show=False)
File "/usr/local/grass-6.5.svn/etc/wxpython/wxgui.py", line 1201, in
NewDisplay
auimgr=self._auimgr, showMapDisplay=show)
File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/wxgui_utils.py",
line 106, in __init__
Map=self.Map, auimgr=self.auimgr)
File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/mapdisp.py",
line 259, in __init__
self.MapWindow.ZoomHistory(self.Map.region['n'],
KeyError: 'n'
I have read README already.
There are not others gdal install in the system: all packages from
official Ubuntu repositories have been completely removed by apt.
It seems wx can't find gdal (libgdal1.5.0.so.1 ): but I compiled gdal
from svn source which version is >=1.6.
I compiled following the script attached (not a true scrip, just a
reminder and same notes about what I'm going to do! If it works it
will be useful). I updated my /etc/ld.so.conf and run ldconfig as
root. I also link grass library into gdal directory and compile
gdal-grass plugin -with-grass=${DIR_INST_GRASS} and
--with-gdal=${DIR_INST_GDAL}/bin/gdal-config.
What's wrong?
Paolo C.
Lat. 44° 39' 11.08'' N Long. 7° 23' 25.26'' E
#! /usr/bin/env bash
PROGRAM=`basename $0`
CURRENTDIR="`pwd`"
# # # gdal source directory
DIR_SRC_GDAL="/usr/local/src/gdal"
# # # gdal install directory
DIR_INST_GDAL="/usr/local/gdal"
# # # grass source directory
DIR_SRC_GRASS="/usr/local/src/grass6_devel"
# # # grass install directory
DIR_INST_GRASS="/usr/local/grass-6.5.svn"
# # # plugin grass-gdal source directory
DIR_SRC_PLUGIN="/usr/local/src/gdal-grass-1.4.3"
# # # plugin grass-gdal install directory
DIR_INST_PLUGIN="/usr/local/lib/gdalplugins"
ask_yes_no()
local yn=
while [ "$yn" = "" ]; do
echo "$1"
read yn
case $yn in
y|Y) yn=0 ;;
n|N) yn=1 ;;
e|E)
# cd ${CURRENTDIR}
exit 1 ;;
*) yn=
echo "Invalid response - please answer y or n"
esac
done
return $yn
if ask_yes_no "Update/upgrade system [Y/N/(E)xit] ?"; then
sudo apt-get update
sudo apt-get upgrade
fi
# # # GDAL - Geospatial Data Abstraction Library
# # # cleaning
if ask_yes_no "Clean GDAL source [Y/N/(E)xit] ?"; then
cd ${DIR_SRC_GDAL}
make distclean
fi
# # # upgrade from svn
if ask_yes_no "Upgrade GDAL source from svn [Y/N/(E)xit] ?"; then
# # # FIRST INSTALL:
# # # sudo mkdir /usr/local/src
# # # sudo chown my_user_name:my_user_group /usr/local/src/
# # # cd /usr/local/src
# # # current development version:
# # # svn checkout https://svn.osgeo.org/gdal/trunk/gdal gdal
# # # current stable version:
# # # svn checkout https://svn.osgeo.org/gdal/branches/1.5/gdal gdal
# # # AFTER FIRST INSTALL:
cd ${DIR_SRC_GDAL}
svn up
cd ${CURRENTDIR}
fi
# # # configure ***WITHOUT GRASS***
if ask_yes_no "Configure GDAL [Y/N/(E)xit] ?"; then
cd ${DIR_SRC_GDAL}
./configure \
--with-pg=/usr/bin/pg_config \
--prefix=${DIR_INST_GDAL} \
--with-python \
--with-ogdi \
--with-sqlite \
--with-mysql=/usr/bin/mysql_config \
--with-libtiff=internal \
--without-grass \
cd ${CURRENTDIR}
fi
# # # make
if ask_yes_no "Make GDAL [Y/N/(E)xit] ?"; then
cd ${DIR_SRC_GDAL}
make
cd ${CURRENTDIR}
fi
# # # make install
if ask_yes_no "Install GDAL [Y/N/(E)xit] ?"; then
cd ${DIR_SRC_GDAL}
sudo make install
cd ${CURRENTDIR}
fi
# # # Is directory, where binary have been installed, in PATH variable?
if ask_yes_no "Check if PATH variable contains path to GDAL binaries [Y/N/(E)xit] ?"; then
echo "GDAL binary are here ...${DIR_INST_GDAL}/bin"
echo ""
cd "${DIR_INST_GDAL}/bin"
ls -l
echo "PATH variable:"
echo "$PATH"
fi
if ask_yes_no "You can change PATH variable now...[Y/N/(E)xit] ?"; then
gedit $HOME/.bashrc
fi
# # # GRASS GIS (Geographic Resources Analysis Support System)
# # # cleaning
if ask_yes_no "Clean GRASS source[Y/N/(E)xit] ?"; then
cd ${DIR_SRC_GRASS}
make distclean
cd ${CURRENTDIR}
fi
if ask_yes_no "Upgrade GRASS from svn [Y/N/(E)xit] ?"; then
# # # FIRST INSTALL: (6.5.0 development branch)
# # # Note: development here is discouraged and
# # # should take place in GRASS 7.
# # # svn checkout https://svn.osgeo.org/grass/grass/branches/develbranch_6 grass6_devel
# # # To switch from SVN 'trunk' (now GRASS 7 development)
# # # to 'develbranch_6' (now GRASS 6.4 development) use
# # # cd /path/to/your/local/copy/trunk
# # # svn switch https://svn.osgeo.org/grass/grass/branches/develbranch_6 .
cd ${DIR_SRC_GRASS}
svn up
cd ${CURRENTDIR}
fi
# # # configure GRASS
if ask_yes_no "Configure GRASS [Y/N/(E)xit] ?"; then
cd ${DIR_SRC_GRASS}
# # # --with-gdal="${DIR_INST_GDAL}/bin/gdal-config" \
# # # CFLAGS="-O2 -march=pentium-m -Wall" LDFLAGS="-s"
# # # CFLAGS="-ggdb -Wall -Werror-implicit-function-declaration"
CFLAGS="-g -Wall" LDFLAGS="-s" ./configure \
--with-tcltk-includes=/usr/include/tcl8.5 \
--with-postgres=yes \
--with-postgres-includes=/usr/include/postgresql \
--with-sqlite \
--with-cxx \
--with-blas \
--with-lapack \
--with-cairo \
--with-fftw \
--with-freetype=yes \
--with-readline \
--with-opengl-includes=/usr/include/GL \
--with-mysql \
--with-mysql-includes=/usr/include/mysql \
--with-python=/usr/bin/python2.5-config \
--with-wxwidgets=/usr/bin/wx-config \
--enable-largefile=yes \
--with-proj-includes=/usr/include \
--with-proj-share=/usr/share/proj \
--with-proj-libs=/usr/lib
cd ${CURRENTDIR}
fi
# # # make
if ask_yes_no "Make GRASS [Y/N/(E)xit] ?"; then
cd ${DIR_SRC_GRASS}
make
cd ${CURRENTDIR}
fi
# # # make vdigit nviz
if ask_yes_no "Make vdigit and nviz [Y/N/(E)xit] ?"; then
# # # symbolic link (overwrite if exists)
sudo ln -s -f /usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so \
/usr/local/lib/libgdi.so
cd "${DIR_SRC_GRASS}/gui/wxpython/vdigit"
make
cd "${DIR_SRC_GRASS}/gui/wxpython/nviz"
make
cd ${CURRENTDIR}
fi
# # # make install
if ask_yes_no "Install GRASS [Y/N/(E)xit] ?"; then
cd ${DIR_SRC_GRASS}
sudo make install
cd ${CURRENTDIR}
fi
# # # check/set/modify shared library
if ask_yes_no "Check ld.so.conf [Y/N/(E)xit] ?"; then
echo ""
echo "REMEMBER: ${DIR_INST_GRASS}/lib must be shared!"
echo ""
cat /etc/ld.so.conf
fi
# # # /etc/ld.so.conf
if ask_yes_no "Modify ld.so.conf [Y/N/(E)xit] ?"; then
sudo gedit /etc/ld.so.conf
sudo ldconfig
fi
# # # PLUGIN GDAL - GRASS
# # # http://download.osgeo.org/gdal/gdal-grass-1.4.3.tar.gz
if ask_yes_no "Compile gdal-grass plugin [Y/N/(E)xit] ?"; then
# # # FIRST INSTALL
# # # tar xfvz gdal-grass-1.4.3.tar.gz
cd ${DIR_INST_GDAL}/lib
# # # link GRASS libs to the lib/ folder
sudo ln -sf ${DIR_INST_GRASS}/lib/*.so .
cd ${DIR_SRC_PLUGIN}
make distclean
./configure --with-grass=${DIR_INST_GRASS} \
make
# # # sudo mkdir /usr/local/lib/gdalplugins # # # first install
sudo cp *.so ${DIR_INST_PLUGIN}
fi
