[GRASS-user] problem in grass70 compilation
orkun temiz at deprem.gov.tr
Sat Jan 31 05:31:16 EST 2009
here are the errors in grass70 compilation
Errors in:
/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/general/g.cairocomp
/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/imagery/i.atcorr
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you
will
also get errors from anything which uses the library.
Finished compilation: Sat Jan 31 12:14:53 EET 2009
make: *** [default] Error 1
cd /usr/local/grass-7.0.svn_src_snapshot_2009_01_24/general/g.cairocomp
orkun at orkun-desktop:/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/general/g.cairocomp$ make
gcc
-L/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/lib -Wl,--export-dynamic -Wl,-rpath-link,/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/lib   -o /usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/bin/g.cairocomp OBJ.i686-pc-linux-gnu/main.o  -lgrass_gis -lgrass_datetime -lz     -lXrender -lcairo -lX11      -lm  -lz
OBJ.i686-pc-linux-gnu/main.o: In function `init_xlib':
/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/general/g.cairocomp/main.c:118: undefined reference to `cairo_xlib_surface_get_xrender_format'
collect2: ld returned 1 exit status
orkun at orkun-desktop:cd /usr/local/grass-7.0.svn_src_snapshot_2009_01_24/imagery/i.atcorr$ make
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/6s.o -c 6s.cpp
/bin/sh:
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include: not found
make: [OBJ.i686-pc-linux-gnu/6s.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/Abstra.o -c Abstra.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/Abstra.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/AerosolConcentration.o -c AerosolConcentration.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/AerosolConcentration.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/AerosolModel.o -c AerosolModel.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/AerosolModel.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/Altitude.o -c Altitude.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/Altitude.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/AtmosModel.o -c AtmosModel.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/AtmosModel.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/common.o -c common.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/common.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/computations.o -c computations.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/computations.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/gauss.o -c gauss.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/gauss.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/GeomCond.o -c GeomCond.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/GeomCond.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/Interp.o -c Interp.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/Interp.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/Iwave.o -c Iwave.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/Iwave.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/main.o -c main.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/main.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/Output.o -c Output.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/Output.o] Error 127 (ignored)
I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include     -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/Transform.o -c Transform.cpp
/bin/sh:
make: [OBJ.i686-pc-linux-gnu/Transform.o] Error 127 (ignored)
L/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/lib -Wl,--export-dynamic -Wl,-rpath-link,/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/lib   -o /usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/bin/i.atcorr OBJ.i686-pc-linux-gnu/6s.o OBJ.i686-pc-linux-gnu/Abstra.o OBJ.i686-pc-linux-gnu/AerosolConcentration.o OBJ.i686-pc-linux-gnu/AerosolModel.o OBJ.i686-pc-linux-gnu/Altitude.o OBJ.i686-pc-linux-gnu/AtmosModel.o OBJ.i686-pc-linux-gnu/common.o OBJ.i686-pc-linux-gnu/computations.o OBJ.i686-pc-linux-gnu/gauss.o OBJ.i686-pc-linux-gnu/GeomCond.o OBJ.i686-pc-linux-gnu/Interp.o OBJ.i686-pc-linux-gnu/Iwave.o OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/Output.o OBJ.i686-pc-linux-gnu/Transform.o  -lgrass_gis -lgrass_datetime -lz       -lm  -lz
make:
L/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/lib: Command not found
make:
[/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/bin/i.atcorr] Error 127 (ignored)
if
[ "/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/bin/i.atcorr" != "" ] ; then GISRC=/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/demolocation/.grassrc70 GISBASE=/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu PATH="/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/bin:$PATH" PYTHONPATH="/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/etc/python:$PYTHONPATH" LD_LIBRARY_PATH="/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/bin:/usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/lib:" LC_ALL=C /usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/bin/i.atcorr --html-description < /dev/null | grep -v '</body>\|</html>' > i.atcorr.tmp.html ; fi
/bin/sh: /usr/local/grass-7.0.svn_src_snapshot_2009_01_24/dist.i686-pc-linux-gnu/bin/i.atcorr: not found
make: *** [i.atcorr.tmp.html] Error 1
rm i.atcorr.tmp.html
kind regards
On Fri, 2009-01-30 at 11:38 +0100, Markus Neteler wrote:
> On Fri, Jan 30, 2009 at 10:25 AM, orkun <temiz at deprem.gov.tr> wrote:
> > hello
> > when I tried to compile grass70, I got this error message
> > Errors in:
> > what do I have to do ?
> please:
> make
> and post the error, and
> make
> and post the error (preferably to the grass-dev list).
> regards
> Markus
Ahmet Temiz
Jeo. Müh.
Afet İşleri Gen. Md.lüğü
Deprem Ar. D.
Ahmet Temiz
Geo. Eng.
General Dir. of
Disaster Affairs
TURKEY
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
