[GRASS-user] some problems in grass622 (ubuntu binaries)
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sat Jan 31 11:54:01 EST 2009
On Thu, 2009-01-29 at 13:00 +0100, Nikos Alexandris wrote:
> On Thu, 2009-01-29 at 13:31 +0200, orkun wrote:
> > thank you
> > As far as I see from the url address you have
> > given there is similar problem with GRASS 6.4.0RC2.
> > regards
> Orkun,
> give it a try to get latest stuff. You'll see it probably will work.
> BTW, which version of gdal do you have installed currently?
> Nikos
Orkun,
my apologies for returning in this post. I see (in another thread) that
you try to compile grass70 (=grass_trunk). I was not very clear when I
wrote "try to get latest stuff".
If you want a "workable+safe" grass installation then you should
probably get latest grass64 or grass65(=grass6_devel). I think that
developers will agree that grass7 is still under "heavy development".
(Or maybe I am wrong... ?)
I have no problems compiling grass63, grass64 and grass65 under Ubuntu
(64-bit). However, grass70 is changing quite fast and some times there
are problems.
Kind regards, Nikos
