[GRASS-user] Re: grass-user Digest, Vol 39, Issue 2
Michael Barton
michael.barton at asu.edu
Wed Jul 1 11:22:34 EDT 2009
On Jul 1, 2009, at 8:02 AM, grass-user-request at lists.osgeo.org wrote:
> Date: Wed, 1 Jul 2009 06:16:52 -0700 (PDT)
> From: Timmie <timmichelsen at gmx-topmail.de>
> Subject: Re: [GRASS-user] link to datasets from other locations?
> To: grass-user at lists.osgeo.org
> Message-ID: <1246454212138-3188925.post at n2.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> hamish-2 wrote:
>>> How do I link to a raster and vector data in another
>>> location presuming it has the same projection?
>> add the mapset as a symlink to the mapset in the other location,
>> then use the @othermapset notation.
> So sharing data between locations is not really supported?
> Even if I just want to add the layer to the map view?
> Regards,
> Timmie
An important concept behind locations is that all maps in a location
share the same projection. Different locations can have different
projections. With the exception of georectification, you can only
display and manipulate maps from a single location during a working
session. In this way you are guaranteed (well almost guaranteed) that
all your maps will share the same projection and will overlay correctly.
Michael
