[GRASS-user] Re: link to datasets from other locations?
    Micha Silver
    micha at arava.co.il
    Thu Jul  2 07:17:26 EDT 2009
Nikos Alexandris wrote:
> Hamish:
>> *every* single GIS I have seen which does on-the-fly reprojection has
>> had major problems which can present itself in a way which is not
>> obvious to the user (typically due to mixed datums).
>> Then the user happily goes along doing their work, publishing their
>> reports, only sometimes realizing that something has misaligned
>> internally.
>> Or ugly non-solutions like rubber sheet dragging to visually correct
>> the misalignment without considering the real cause become taught as
>> the de facto method in the workflow. (easier than teaching about
>> ellipsoids and datum math)
> Added in GRASS-wiki [1]:
And in addition I entered a paragraph in the "Tips for Arc Users" page
http://grass.osgeo.org/grass-wiki/Tips_for_Arc_users
since the original question reflected a misunderstanding that some of us
Arc converts have to deal with.
Micha
> "GRASS' logical database structure (one projection definition per
> LOCATION) is designed to avoid problems such as the ones introduced with
> the "on-the-fly" reprojection ability (typically problems caused by
> mixed datums) which is present in most GISes."
> Nikos
> [1] http://grass.osgeo.org/wiki/Location_and_Mapsets
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
