[GRASS-user] GRASS 6.4.0 Windows, problem with digitizing tool
Dominik Wiedner
dominikwiedner at web.de
Fri Jul 3 11:20:45 EDT 2009
hamish-2 wrote:
> steps used?
> for me on Linux it works:
> [x] New map
> new vector map name= test_map1
> Display commands = d.rast elevation.dem
> whole command looks like:
> v.digit -n map=test_map1 {bgcmd=d.rast elevation.dem}
Hi Hamish,
Just typed in the command, just as shown in your example, but still the
result remains the same: I can start to create vectors (point, line an
polygon) but the raster file (an imported ERDAS Imagine 9.2 file) which
shall serve as a source is not being loaded into the digitizing window!
View this message in context: http://n2.nabble.com/GRASS-6.4.0-Windows%2C-problem-with-digitizing-tool-tp3196193p3201887.html
Sent from the Grass - Users mailing list archive at Nabble.com.
