[GRASS-user] v.db.connect additional attribut table
Falko Engel
falko_e at gmx.net
Sat Jul 4 11:38:09 EDT 2009
Dear List,
I am still running into problems with connecting an additional attribute
table to an existing map.
I am using postgres to store all tables in. This is my setup: GRASS 6.4
RC5, Suse 11.1, and Postgresql 8.3.7.
I have a polygon (area, centroid) map containing my whole study area.
There are about 10000 polygones in this map.
In an additional table with about 300 rows I have extra information for
some of the posygones of the original geometry.
In the map's original attribute table there is a colum with an
identifier that is also used in the additional table. It is in string
format.
Can someone tell me how I can connect the table to the map as a second
layer?
Heres what I already did:
# Reclass cats of map according to identifier column
v.reclass input=map output=map_reclass column=identifier
# Using SQL
# Update an integer column "table_id" in the new table with the cat
values of the map according to the identifier column
UPDATE new_table
SET table_id = map_reclass.cat
FROM map_reclass
WHERE new_table.identifier = map_reclass.identifier
v.db.connect -o map=map_reclass key=table_id layer=2 table=new_table
v.category map_reclass option=add layer=2 output=map_reclass_layer2
I am sure there is something wrong because I can't work with layer 2
after this operation.
v.category input=map_reclass_layer2 option=report
Layer/Tabelle: 2/map_reclass_layer2_2
Typ Anzahl Min Max
Punkt 0 0 0
Linie 0 0 0
Grenze 26072 1 26072
Zentroid 10205 26073 36277
Fläche 0 0 0
Alle 36277 1 36277
Layer/Tabelle: 1/map_reclass_layer2_1
Typ Anzahl Min Max
Punkt 0 0 0
Linie 0 0 0
Grenze 0 0 0
Zentroid 10115 1 8543
Fläche 0 0 0
Alle 10115 1 8543
Thanks for any help!
Falko
