[GRASS-user] AVIRIS data in GRASS [SEC=UNCLASSIFIED]
Andrew MacIntyre Andrew.MacIntyre at acma.gov.au
Mon Jul 6 02:16:10 EDT 2009
Hamish wrote:
> also I suspect Python can do binary reads in a clean way, which
> may help if the expected format was known.
Python's struct and array modules are a good starting point for
handling binary data.
Numpy (http://numpy.scipy.org/, can be built with NetCDF support)
is a third party module of considerable utility.
Andrew.
-------------------------> "These thoughts are mine alone!" <---------
Andrew MacIntyre           National Licensing and Allocations Branch
tel:   +61 2 6219 5356     Inputs to Industry Division
fax:   +61 2 6253 3277     Australian Communications & Media Authority
email: andrew.macintyre at acma.gov.au            http://www.acma.gov.au/
If you have received this email in error, please notify the sender immediately and erase all copies of the email and any attachments to it. The information contained in this email and any attachments may be private, confidential and legally privileged or the subject of copyright. If you are not the addressee it may be illegal to review, disclose, use, forward, or distribute this email and/or its contents.
Unless otherwise specified, the information in the email and any attachments is intended as a guide only and should not be relied upon as legal or technical advice or regarded as a substitute for legal or technical advice in individual cases. Opinions contained in this email or any of its attachments do not necessarily reflect the opinions of ACMA.
