[GRASS-user] .e00 to DEM
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Jul 8 12:19:39 EDT 2009
On Wed, 2009-07-08 at 10:57 -0500, stephen sefick wrote:
> The data I would like to import in GRASS is here:
> http://csat.er.usgs.gov/statewide/layers/dem250.html
> I have tried r.in.gdal with no sucess. I will provide anything that
> is helpfull. This is my second post, so I don't know what would be
> helpful.
> thanks for the help,
Hi.
I've downloaded the GRID [1] file. "gdalinfo" works (with some reported
errors) on the "dem250/" directory which is stored within "workspl"[2].
So I created a location based on the data itself (using the dem250
directory as a source) and imported in grass with r.in.gdal (again using
the dem250 directory as input).
# enter in _some_ location and create another-one based on the data
g.proj -c location=albers_us georef=/geo/geodata/world/us/worksp1/dem250
# exit from current location, enter in newly created one
grass64 /geo/grassdb/global/albers_us/PERMANENT/
# import data
r.in.gdal in=/geo/geodata/world/us/workspl/dem250 out=dem250
There is something strange with the values though (they expand from min
= -32687 max = 32645). Don't have the time to dig further, maybe there
are details in the meta-data about it (!?).
Good Luck, Nikos
[1] http://csat.er.usgs.gov/download/statewide/dem250grid.zip
[2] gdalinfo dem250/
ERROR 3: Attempt to read past EOF in dem250//../info/arc.dir.
ERROR 4: Failed to open table .VAT
Driver: AIG/Arc/Info Binary Grid
Files: dem250/
dem250/dblbnd.adf
dem250/hdr.adf
dem250/log
dem250/prj.adf
dem250/sta.adf
dem250/vat.adf
dem250/w001001.adf
dem250/w001001x.adf
Size is 7495, 8622
Coordinate System is:
PROJCS["unnamed",
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AUTHORITY["EPSG","4269"]],
PROJECTION["Albers_Conic_Equal_Area"],
PARAMETER["standard_parallel_1",29.5],
PARAMETER["standard_parallel_2",45.5],
PARAMETER["latitude_of_center",23],
PARAMETER["longitude_of_center",-83.5],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["METERS",1]]
Origin = (-190574.428637420991436,1327208.631963560357690)
Pixel Size = (60.000000000000000,-60.000000000000000)
Corner Coordinates:
Upper Left ( -190574.429, 1327208.632) ( 85d36'18.54"W, 34d59'5.20"N)
Lower Left ( -190574.429, 809888.632) ( 85d29'8.74"W, 30d20'49.23"N)
Upper Right ( 259125.571, 1327208.632) ( 80d38'16.82"W, 34d58'7.57"N)
Lower Right ( 259125.571, 809888.632) ( 80d48'1.00"W, 30d19'54.45"N)
Center ( 34275.571, 1068548.632) ( 83d 7'56.55"W, 32d41'16.79"N)
Band 1 Block=20x4 Type=Int16, ColorInterp=Undefined
Min=0.000 Max=1371.000
NoData Value=-32768
