[GRASS-user] Problems with v.in.ogr importing shp files
Ferruccio Sarra ferruccio.sarra at tiscali.it
Wed Jul 8 13:20:27 EDT 2009
Hope John solved his issue but it's quite different from mine.
I guess the problem I'm facing with v.in.ogr function have been solved
by Jachym Cepicky (
http://n2.nabble.com/grass-gdal-ubuntu-issue-solved-(-)-td2352498.html
), whose unofficial repository hold some updated packages that seems to
work very well... Unfortunately I'm working on a 64bit pc with Ubuntu
9.04 and  no package for this configuration is available there.
I compiled a Grass 6.5 from source but really don't know on how to
compile a more recent version of gdal and even don't know exactly wich
libraries have to be updated.
Some useful suggestion on what to do to make v.in.ogr work correctly
with shp files?
Thank you in advance.
Ferro
Jhon Ortiz ha scritto:
>> Hi all.
>> Compiled and installed Grass 6.5 from source on a 64x Ubuntu 9.04
>> machine. It seemed to me it worked fine but when I tried to import the
>> curvespear shape file (following the step by step tutorial
>> http://www.ing.unitn.it/~grass/docs/tutorial_62/index.html ) by v.in.ogr
>> function, the procedure didn't go on. In the output window:
>> Layer: curvespear
>> Importing map 1755 features...
>> and nothing else.
>> The imported file is in the right place but with nearly no feature inside.
>> I'v been looking for a tip in the user mailing list archive but Rafael
>> Moraes suggestion doesn't help.     Added      http://les-ejk.cz/ubuntu
>> repository to source list     and reinstalled gdal... but nothing happend.
>>    The same with Grass 6.2.3. (Maybe I made some newbe mistake in
>> updating gdal).
>> Any suggestion?
>> Thank you.
>> Ferro
>> P.S
> Hi all,
> I have the same problem when I tried to import the shapefile with v.in.org
> I'm working with GRASS 6.4.0svn on a 64x Ubuntu 9.04
> In the terminal give this errors
> GRASS 6.4.0svn (Prueba_location):~ > *** buffer overflow detected ***: v.in.ogr terminated
> ======= Backtrace: =========
> /lib/libc.so.6(__fortify_fail+0x37)[0x7f95d00bc2c7]
> /lib/libc.so.6[0x7f95d00ba170]
> /lib/libc.so.6[0x7f95d00b97ab]
> /lib/libc.so.6(__snprintf_chk+0x7b)[0x7f95d00b967b]
> /usr/lib/libgdal1.5.0.so.1(_ZN10OGRFeature16GetFieldAsStringEi+0x346)[0x7f95d0de2296]
> v.in.ogr(main+0x2284)[0x406b50]
> /lib/libc.so.6(__libc_start_main+0xe6)[0x7f95cffdb5a6]
> v.in.ogr[0x403969]
> Some advice?
> Thaks
> John Ortiz
> _________________________________________________________________
> Llévate Messenger en el móvil a todas partes ¡Conéctate!
> http://www.microsoft.com/spain/windowsmobile/messenger/default.mspx
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
