[GRASS-user] r.in.wms failure
    Agustin Diez Castillo
    adiez at uv.es
    Thu Jul  9 09:28:56 EDT 2009
r.in.wms is a big problem, on my side, I haven't been able to download
but from the NASA server, in Spain we got a bunch of wms servers and
AFAICT none works with r.in.wms, surely, it's a problem of
(mis)understanding the parameters but I use the same services all the
time with GIS other than grass w/o problems.
An unsuccessful r.in.wms
First of all, I can assure that http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx?
  is a pretty stable server but does not work with my [lack] of
knowledge, I will be grateful if somebody explain what I'm doing wrong.
i.e.
g.region -p
projection: 1 (UTM)
zone:       30
datum:      eur50
ellipsoid:  international
north:      4290000
south:      4280000
west:       715000
east:       735000
nsres:      10
ewres:      10
rows:       1000
cols:       2000
cells:      2000000
r.in.wms -l output=cccc mapserver=http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx?
  format=png maxcols=1024 maxrows=1024 method=nearest
returns the following
List of layers for server <http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx?
2009-07-09 15:13:32 URL:http://ovc.catastro.meh.es/Cartograf
ia/WMS/ServidorWMS.aspx? [316/316] -> "/Users/adiez/Document
s/grassdata/nueva/adiez2/.tmp/boquique.prearq.uv.es/56792.0c
apabilities.xml" [1]
The 'xml2' program was not found. Proceeding with internal XML parsing
which may not be as reliable.
ERROR: Parsing XML file
<?xml version='1.0' encoding="ISO-8859-1"  standalone="no" ?>
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InvalidFormat">
<![CDATA[
Unable to encode text. Please set encoding in GUI preferences.
  </ServiceException>
</ServiceExceptionReport>
(Thu Jul  9 15:13:33 2009) Command finished (0 sec)
with get I'm able to get the layers but when I try something else:
<![CDATA[
  </ServiceException>
(Thu Jul  9 15:16:08 2009)
r.in.wms -l -g output=cccc mapserver=http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx?
		n~OGC:WMS~
		nt --Cartografia catastral
		n
			nLAYER:
				n~Catastro~
				nt --Catastro
                 nStyle:
                   n~Default~
                   nt --Default
			nLAYER:
				n~CONSTRU~
				nt --CONSTRU
                 nStyle:
                   n~Default~
                   nt --Default
			nLAYER:
				n~TXTCONSTRU~
				nt --TXTCONSTRU
                 nStyle:
                   n~Default~
                   nt --Default
			nLAYER:
				n~SUBPARCE~
				nt --SUBPARCE
                 nStyle:
                   n~Default~
                   nt --Default
			nLAYER:
				n~TXTSUBPARCE~
				nt --TXTSUBPARCE
                 nStyle:
                   n~Default~
                   nt --Default
			nLAYER:
				n~PARCELA~
				nt --PARCELA
                 nStyle:
                   n~Default~
                   nt --Default
			nLAYER:
				n~TXTPARCELA~
				nt --TXTPARCELA
                 nStyle:
                   n~Default~
                   nt --Default
			nLAYER:
				n~MASA~
				nt --MASA
                 nStyle:
                   n~Default~
                   nt --Default
			nLAYER:
				n~TXTMASA~
				nt --TXTMASA
                 nStyle:
                   n~Default~
                   nt --Default
			nLAYER:
				n~EJES~
				nt --EJES
                 nStyle:
                   n~Default~
                   nt --Default
			nLAYER:
				n~LIMITES~
				nt --LIMITES
                 nStyle:
                   n~Default~
                   nt --Default
			nLAYER:
				n~TEXTOS~
				nt --TEXTOS
                 nStyle:
                   n~Default~
                   nt --Default
			nLAYER:
				n~ELEMLIN~
				nt --ELEMLIN
                 nStyle:
                   n~Default~
                   nt --Default
2009-07-09 15:16:08 URL:http://ovc.catastro.meh.es/Cartograf
ia/WMS/ServidorWMS.aspx??service=WMS&request=GetCapabilities
&version=1.1.1 [27412/27412] -> "/Users/adiez/Documents/gras
sdata/nueva/adiez2/.tmp/boquique.prearq.uv.es/56866.0capabil
ities.xml" [1]
(Thu Jul  9 15:16:08 2009) Command finished (0 sec)
(Thu Jul  9 15:17:19 2009)
r.in.wms -g output=cccc mapserver=http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx?
  layers=Catastro styles=default srs=EPSG:23030 format=png
maxcols=1024 maxrows=1024 method=nearest cap_file=catastatro
Calculating tiles
Requesting 2 tiles.
Downloading tiles
Downloading data
2009-07-09 15:17:21 URL:http://ovc.catastro.meh.es/Cartograf
ia/WMS/ServidorWMS.aspx??request=GetMap&layers=Catastro&styl
es=default&srs=EPSG:23030&bbox=715000.00000148000000000000,4
279999.99999735000000000000,725019.98002192594905092907,4290
019.98001840215784213786&width=1003&height=1003&format=image
/png&transparent=TRUE&version=1.1.1 [239/239] ->
"/Users/adiez/Documents/grassdata/wms_download/cccc__0.png"
[1]
Downloading data
es=default&srs=EPSG:23030&bbox=725000.00000194500000000000,4
279999.99999735000000000000,735039.96004237189810185814,4290
"/Users/adiez/Documents/grassdata/wms_download/cccc__1.png"
[1]
All tiles downloaded successfully
ERROR 4:
`/Users/adiez/Documents/grassdata/wms_download/cccc__0.png'
not recognised as a supported file format.
ERROR: GRASS-6.5: gdalwarp failure.
ERROR: r.in.gdalwarp failed
(Thu Jul  9 15:17:22 2009) Command finished (3 sec)
(Thu Jul  9 15:18:41 2009)
r.in.wms -g --overwrite --verbose output=cccc mapserver=http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx?
  layers=Catastro styles=default srs=EPSG:23030 maxcols=1024
maxrows=1024 method=nearest cap_file=catastatro v=5
Using WGET for downloading data.
The verbosity option is superseded. Use --verbose instead
Skipping argument for region
Skipping argument for tileoptions
wms.request
'folder=/Users/adiez/Documents/grassdata/wms_download'
'prefix=cccc' 'mapserver=http://ovc.catastro.meh.es/Cartogra
fia/WMS/ServidorWMS.aspx?' 'layers=Catastro'
'styles=default' 'srs=EPSG:23030' 'format=geotiff'
'wmsquery=version=1.1.1' 'maxcols=1024' 'maxrows=1024'
Calculating tiles
Requesting 2 tiles.
wms.download  -g 'requestfile=/Users/adiez/Documents/grassda
ta/wms_download/cccc_.wget' 'wgetoptions=-c -t 5 -nv'
'curloptions=-C - --retry 5 -s -S'
Downloading tiles
Downloading data
Requesting Data from <http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx?
request=GetMap&layers=Catastro&styles=default&srs=EPSG:
23030
&bbox
715000.00000148000000000000,4279999.99999735000000000000,725019.98002192594905092907,4290019.98001840215784213786
&width=1003&height=1003&format=image/
geotiff&transparent=TRUE&version=1.1.1
2009-07-09 15:18:43 URL:http://ovc.catastro.meh.es/Cartograf
/geotiff&transparent=TRUE&version=1.1.1 [239/239] -> "/Users
/adiez/Documents/grassdata/wms_download/cccc__0.geotiff" [1]
Downloading data
23030
&bbox
725000.00000194500000000000,4279999.99999735000000000000,735039.96004237189810185814,4290019.98001840215784213786
2009-07-09 15:18:44 URL:http://ovc.catastro.meh.es/Cartograf
/adiez/Documents/grassdata/wms_download/cccc__1.geotiff" [1]
r.in.gdalwarp  -c 'input=/Users/adiez/Documents/grassdata/wm
s_download/cccc__0.geotiff,/Users/adiez/Documents/grassdata/
wms_download/cccc__1.geotiff' 'output=cccc' 'method=nearest'
's_srs=EPSG:23030'
ERROR 4: `/Users/adiez/Documents/grassdata/wms_download/cccc
__0.geotiff' not recognised as a supported file format.
(Thu Jul  9 15:18:44 2009) Command finished (2 sec)
[1] http://www.idee.es/show.do?to=pideep_desarrollador_wms.ES
[2] http://www.idee.es/CatalogoServicios/cat2/indexWMS.html
On Jul 9, 2009, at 2:17 PM, Luca Casagrande wrote:
> hamish-2 wrote:
>> Luca wrote:
>>> To use the same server with OpenLayers, I had to set the
>>> size of the tiles to 512px.
>>> Could this be the problem?
>> probably not. arbitrary sizes work for me.
>> I don't know, but OpenLayers might be using the pre-cut tiles as
>> JPL's
>> web page pleads you do, in which case the power-of-2 size makes
>> sense.
> By default OL request a tile of 256px x 256px but this size is too
> small for
> NASA WMS.
> Ciao
> Luca
> View this message in context: http://n2.nabble.com/r.in.wms-failure-tp3227181p3231076.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
