[GRASS-user] Re: Problem with wxGUI.Nviz extension and
wxGUI.Vector_Digitizing_Tool
Tomas Zigo
tomas.zigo at slovanet.sk
Fri Jul 10 17:13:36 EDT 2009
Martin Landa <landa.martin <at> gmail.com> writes:
> Zdravim,
> well, not sure where can be a problem. Usual workflow.
> 1) create a new vector map
> 2) open ATM, go to 'Manage layers"
> 3) create table
> 4) add layer (v.db.connect)
> 5) go to "Manage tables"
> 6) add new column (v.db.addcol)
> Martin
Zdravim,
1)pass
2)pass
3)pass
4)pass
5)pass
6) Error wxpython window : Error in command execution v.db.addcol: Execution
failed: 'v.db.addcol map=Skuska na PERMANENT layer=1 columns=NADM_VYSKA double
precision'
Details:
Error: There is no table connected to this map! Run v.db.connect or
v.db.addtable first.
7) ?
Tomas
