[GRASS-user] Re: r.watershed ending with an error
stephen sefick
ssefick at gmail.com
Fri Jul 10 20:31:00 EDT 2009
Sorry patch_dem was patch_map - The process is still stalling however
On Fri, Jul 10, 2009 at 7:14 PM, stephen sefick<ssefick at gmail.com> wrote:
> 6.4.0RC5
> Mac OS X 10.5.7
> 1.8Ghz 1GB of RAM-
> the only input is the raster patch_dem 1/3arc second
> r.watershed elevation=patch_dem at PERMANENT threshold=10000
> accumulation=accumulation basin=catch stream=str
> this exits with the following message:
> SECTION 1a (of 5): Initiating Memory.
> ERROR: Raster map <patch_dem at PERMANENT> not found
> WARNING: Subprocess failed with exit code 256
> WARNING: category information for [accumulation] in [PERMANENT] missing or
> invalid
> WARNING: category information for [catch] in [PERMANENT] missing or invalid
> WARNING: category information for [str] in [PERMANENT] missing or invalid
> I know catch is not in PERMANENT it is an output etc.
> I have been trying all day with different parameters and I can't
> figure it out. I want to delineate watersheds with there aspects and
> "other cool watershed things". I also want to get the strahler order
> for streams. I was going to use v.strahler, but this addon seems to
> be defunct. I have used it but it writes values to a text file... I
> am thinking of using SAGA for stream ordering- I believe that it has
> this particular feature.
> thanks in advance,
> Stephen Sefick
> Stephen Sefick
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods. We are mammals, and have not exhausted the
> annoying little problems of being mammals.
> -K. Mullis
Stephen Sefick
-K. Mullis
