[GRASS-user] Re: Problem with wxGUI.Nviz extension and
wxGUI.Vector_Digitizing_Tool
Tomas Zigo
tomas.zigo at slovanet.sk
Sat Jul 11 07:12:02 EDT 2009
Hi.
> Martin Landa <landa.martin <at> gmail.com>
1) v.digit -n map=Skuska1
2) v.db.addtable map=Skuska1 table=Skuska1
Using user specified table name: Skuska1
Creating new DB connection based on default mapset settings...
Creating table with columns (cat integer)
The table <Skuska1> is now part of vector map <Skuska1> and may be deleted
or overwritten by GRASS modules
Select privileges were granted on the table
Reading features...
Updating database...
100%
0 records updated/inserted (layer 1)
Current attribute table links:
Vector map <Skuska1 na Polana_a_okolie_1k10000_5m> is connected by:
layer <1> table <Skuska1> in database
</home/tomas/Grass_data/Polana_bakalarska_praca/Polana_a_okolie_1k10000_5m/dbf/>
through driver <dbf> with key <cat>
> db.tables -p
Skuska1
3) v.db.connect map=Skuska1 table=Skuska1 -o
> v.db.connect Skuska1 -g
4) v.db.addcol map=Skuska1 na Polana_a_okolie_1k10000_5m columns="NADM_VYSKA double
precision"
ERROR: There is no table connected to this map! Run v.db.connect or
v.db.addtable first.
Tomas
