[GRASS-user] Re: r.watershed ending with an error
stephen sefick
ssefick at gmail.com
Sun Jul 12 00:12:52 EDT 2009
I did a resample to the current computation region. This made the
colnumxrownum go from 100000x100000 to 1000x1000, and this ran like a
champ. Lesson- don't run a watershed delineation on the entire state
of georgia.
thanks for all of your help,
Stephen Sefick
On Sat, Jul 11, 2009 at 7:07 AM, Markus
Metz<markus.metz.giswork at googlemail.com> wrote:
> stephen sefick wrote:
>> Sorry patch_dem was patch_map - The process is still stalling however
> In what section? What is the size the current computational region, rows
> x columns? Did it go into swap space?
>> On Fri, Jul 10, 2009 at 7:14 PM, stephen sefick<ssefick at gmail.com> wrote:
>>> 6.4.0RC5
>>> Mac OS X 10.5.7
>>> 1.8Ghz 1GB of RAM-
>>> the only input is the raster patch_dem 1/3arc second
>>> r.watershed elevation=patch_dem at PERMANENT threshold=10000
>>> accumulation=accumulation basin=catch stream=str
>>> this exits with the following message:
>>> SECTION 1a (of 5): Initiating Memory.
>>> ERROR: Raster map <patch_dem at PERMANENT> not found
>>> WARNING: Subprocess failed with exit code 256
>>> WARNING: category information for [accumulation] in [PERMANENT] missing or
>>> invalid
>>> WARNING: category information for [catch] in [PERMANENT] missing or invalid
>>> WARNING: category information for [str] in [PERMANENT] missing or invalid
>>> I know catch is not in PERMANENT it is an output etc.
>>> I have been trying all day with different parameters and I can't
>>> figure it out. I want to delineate watersheds with there aspects and
>>> "other cool watershed things". I also want to get the strahler order
>>> for streams. I was going to use v.strahler, but this addon seems to
>>> be defunct. I have used it but it writes values to a text file... I
>>> am thinking of using SAGA for stream ordering- I believe that it has
>>> this particular feature.
>>> thanks in advance,
>>> Stephen Sefick
>>> Stephen Sefick
>>> Let's not spend our time and resources thinking about things that are
>>> so little or so large that all they really do for us is puff us up and
>>> make us feel like gods. We are mammals, and have not exhausted the
>>> annoying little problems of being mammals.
>>> -K. Mullis
Stephen Sefick
-K. Mullis
