[GRASS-user] Convert OGR vector layer to GRASS vector map
benton101
benton.davies at gmail.com
Wed Jul 15 04:13:28 EDT 2009
Markus Wrote:
>> You should use areas not boundaries. A GRASS area consists of a set of
boundaries plus a centroid. Areas without centroids are usually (part
of) isles aka holes. ... Are there lines or polygons in the shapefile to be
imported?
The shapefile that I used is a shapefile of polygons, does this pass for an
area with a centroid?
>>What v.in.ogr command did you use?
This is the command I used ... v.in.ogr --overwrite --verbose dsn=V:\lcu.shp
output=lcu
>> Have you imported boundaries or lines?
I am hoping that I have imported boundaries, can you tell from my v.in.ogr
command?
Thank You
Ben
View this message in context: http://n2.nabble.com/Convert-OGR-vector-layer-to-GRASS-vector-map-tp3260449p3261719.html
Sent from the Grass - Users mailing list archive at Nabble.com.
