[GRASS-user] Convert OGR vector layer to GRASS vector map
benton101 benton.davies at gmail.com
Wed Jul 15 21:01:55 EDT 2009
Hi Markus,
After reading this post through I have completed the process again and have
had a successful outcome creating a file with statistics using v.rast.stats.
I have no idea where I went wrong in the previously but I have a feeling
adding centroids was the point where things went a rye.
But I do have one comment;
I had success using 6.4.0svn with xp, but when I carried out the same
process using 6.4.0R5C I ran into the "no categories found in raster map
error" problem I posted in a July 15 post. The raster was the same in both
instances. My intent in both instances was to use v.rast.stats and it is
this command that produced the problem in 6.4.0R5C.
Thank You
Ben
View this message in context: http://n2.nabble.com/Convert-OGR-vector-layer-to-GRASS-vector-map-tp3260449p3266681.html
Sent from the Grass - Users mailing list archive at Nabble.com.
