[GRASS-user] The geotiff format problem
Markus Neteler neteler at osgeo.org
Thu Jul 16 16:33:28 EDT 2009
On Thu, Jul 16, 2009 at 3:10 PM, maven apache<apachemaven0 at gmail.com> wrote:
> Hi all:
> I have exported the roads in the Spanish example DataBase to a geotiff and
> post it through the wcs.
> Then I want to handle it :
> 1)download the tiff in my webservice.
> 2)use the geotools to parser the tiff,however I got the errors:GeoKey
> directory does not exist.
> So I wonder the geotiff from the grass is not identified by the geotools?
Did you use r.out.gdal? (which GRASS version)?
If yes, then the GDAL library is responsible since GRASS calls GDAL to
generate the file. In that case the gdal-dev list may be of better help.
If no, please tell us how you exported.
Markus
