[GRASS-user] m.proj transformation to EPSG3785 / KML
    Hamish
    hamish_b at yahoo.com
    Mon Jul 20 14:16:36 EDT 2009
Hi Peter,
> how can m.proj (being the frontend to cs2cs) be configured
> to create output in the "Google projection" (aka EPSG 900913
> / EPSG 3785) ?
just use the expanded version as proj_out proj4 terms.
> These EPSG codes are currently not included in
> /usr/share/proj/epsg.
they can be found in /usr/share/proj/esri.extra
FWIW & AFAIK, KML takes coordinates as wgs84 LL, and the "Google
projection" is a highly dubious beast that should be avoided if
at all possible.
Hamish
