[GRASS-user] Raster histogram or r.info for raster min/max values
Frank Bilki fbilki at gmail.com
Tue Jul 21 03:12:43 EDT 2009
Hello Hamish,
Thanks so much for the very comprehensive reply -- it's much
appreciated. I must confess it's a bit beyond me at the moment but I'm
sure it will make more sense over time.
The distinction between the default region and the individual scenes
is very good to know - thank you. I had set the default region to the
native resolution of the scenes and extents of the entire mosaic, but
perhaps it would be better to maintain a separate region for each
scene while I'm pre-processing them?
I have been using i.landsat.rgb for display with good success, but
clipping histograms is a bit different from dark pixel correction,
which normalises the scenes in preparation for downstream calculations
like band ratios, classification, and so on. I've noticed i.atcorr but
such a comprehensive correction is beyond my needs (and understanding)
at the moment.
Thanks again. I will now go away and carefully contemplate your
answers before continuing ... which will no doubt raise the next set
of questions!
Cheers,
Frank
On Tue, Jul 21, 2009 at 2:20 PM, Hamish<hamish_b at yahoo.com> wrote:
> Hi,
> Frank wrote:
>> I am trying to perform a dark pixel correction on a Landsat ETM
>> mosaic consisting of 15 scenes. For each band in each scene I
>> need to determine the minimum brightness value and then subtract
>> that 'bias' from the entire band. I have figured out how to use
>> r.mapcalc to do the subtraction, but I am getting what appears to be
>> conflicting results when I attempt to calculate the minimum value.
> did you try yet the i.landsat.rgb module? you may look inside the
> script with a text editor to see/adjust the method used.
> example: http://grass.osgeo.org/screenshots/rs.php
> It uses the r.univar module's percentile= option to chop away the
> bottom x% of pixel values, rather than assume the minimum value seen
> is worth keeping and not just an outlier.
> Note that it does not touch data values, it only adjusts the colors.
>> My operating system is Windows Vista Business and I am using GRASS
>> 6.4.0svn under the wxPython user interface. My dilemma is this:
>> If I run r.info on Band 3 (visible red) for a particular
>> scene I get this result:
>> Range of data:    min = 1  max = 255
> ok.
> note r.info works on the map's metadata (so full extent), while r.univar
> (and most other raster modules) work on the current region settings (zoom
> extent).
> also if current region resolution does not match the map's native
> resolution some resampling will happen which may cause it to skip cells,
> and so the minimum value might be hidden.
> (see g.region help page and raster intro help page)
> the command shell (dos box) way would be:
>  g.region rast=your_map   # (zoom to match extent of that map)
>  r.univar your_map
>> Given that this band is visible red I would expect a minimum value
>> somewhat greater than 1 -- a value of between 5 and 10 would be more
>> appropriate for this region.
>> If I display the raster histogram (using the Analyze button on the Map
>> Display window), the x-axis extends anywhere from around 10 to around
>> 235 (in a small window) or from 6 to around 247 (if I span the window
>> across both monitors).
> ....hmmm so the wxGUI histogram works on the Map Display region instead
> of the computational one?  (I'm not an expert on the ins and outs of the
> GUI, not sure if that is true or not, nor which way is more appropriate)
> try "zoom to current layer"
>> And, yes, I know the x-axis units are 'in tens'.
> the axis scaling is dynamic dependent on the data.
>> Varying the size of the window has a major effect on the
>> histogram! It is not a visual error - the first tic clearly changes
>> relative to the y-intercept.
>> Which result do I believe?
> The d.histogram module which generates that is a little bit crusty,
> but all it does is run and plot up the results of r.stats. So I'd
> suggest to run r.stats.
>> I do not trust the minimum values from r.info.
> Trust them, but realize that it represents the entire map, not just
> the current zoom settings.
>> What I would really like is to generate a summary of the
>> number of pixels with each brightness value from 0 to 255.
>> Is there an easy way to do that?
> sure:
> g.region rast=your_map.red # (eg red band, all bands should be the same)
> r.stats -c your_map.red
> then cut and paste output into your favorite plotting program to create
> the histogram.
> I don't think/know that this would work on Windows, but for Mac and
> Linux users a way to recreate d.histogram using the d.linegraph module:
> r.stats -c your_map.red | cut -f1 -d' ' > Xs
> r.stats -c your_map.red | cut -f2 -d' ' > Ys
> d.mon x0
> d.linegraph x_file=Xs y_file=Ys
> (dev note: it seems d.linegraph and d.histogram share code, if either is
> to remain for GRASS7 recent bug fixes to d.histo should be ported over to
> d.linegraph. personally I wouldn't mind to see PyPlot replace them both)
>> I have only been using GRASS a couple weeks and have not
>> figured out how to script it yet, so would prefer the
>> solution to involve the UI.
> ok, so I have failed badly in that regard but hopefully it helps explain
> some of the underlying logic and give you an idea of what to look for
> in the menus.
> (dev note- TODO: get module synopsis PDF* to show GUI menu hierarchy
> location for each module name. prototype code can be found in
> find_menu_hierarchy() in tools/module_synopsis.sh)
> [*] http://grass.ibiblio.org/gdp/grassmanuals/grass64_module_list.pdf
> Hamish
