[GRASS-user] Re: Building topologically correct stream network
Jarek Jasiewicz
jarekj at amu.edu.pl
Tue Jul 21 15:02:36 EDT 2009
Markus Metz pisze:
> Hi Jarek
> Jarek Jasiewicz wrote:
>> Hi
>> maybe this will help:
>> http://gis.vsb.cz/GIS_Ostrava/GIS_Ova_2009/sbornik/Lists/Papers/060.pdf
> What were the limitations of the GRASS raster-to-vector conversion
> tools you encountered?
that problems are shown on fig 4)
1) streams directions are not correct (are random) because we have no
information about its directions in raster file
2) there are problems if streamlines toutch each other like
> It's not clear to me from Fig. 3, but I would like to understand the
> problem, and I hope you can explain it in a bit more detail.
In fact I use script to convert Terrain Analysis System data to Grass
topological data. I attached it here (note it is not GRASS script with
full error handling). Sorry for polish comment but I have not time to
translate it. If you need more information how it works contact me off list.
Jarek
BTW I'm about to finish regular grass modue for calculating Strahler
Stream order and Shreeve Stream Magnitude. I hope I publish it for
testing in next few days. Any help appreciated.
> Thanks a lot,
> Markus M
#!/bin/bash
zlewnia=`eval g.gisenv get=MAPSET`
cieki='cieki_'$zlewnia
vertex='vertex_'$zlewnia
vector='index_vector'
links='index' #unikalne numery strumieni
class='class' #klasy punktów/odcinków (arc/nodes)
strahler='strahler' #plik z strahler stream order
shrevee='sreeve' #plik z strahler stream order
main='main'
#hierarchia zlewni
zlewnia_elem='elem'
z1='w1'
z2='w2'
z3='w3'
z4='w4'
z5='w5'
z6='w6'
#parametry morfometryczne strumieni
elev='elev'
elev2main='elev2main'
slope='slope'
planc='planc'
profc='profc'
maxic='maxic'
diff5='diff5'
diff9='diff9'
diff15='diff15'
####### Koniec definicji ###
db.connect driver=pg database='rzeki_mgr'
g.mremove -f rast=tmp* vect=tmp* &2>/dev/null #usuÅ tempy jeżeli istniejÄ
g.remove -f vect=$cieki &2>/dev/null #usuÅ wynikowy plik jeÅżeli istnieje
echo 'DROP table tmp_streams'|db.execute &2>/dev/null #usuÅ tabelÄ tmp_streams jeżeli istnieje
echo 'DROP table tmp_streams_param'|db.execute &2>/dev/null #usuÅ tabelÄ tmp_streams jeżeli istnieje
#echo 'DROP table tmp_katy'|db.execute &2>/dev/null #usuÅ tabelÄ tmp_streams jeżeli istnieje
echo 'DROP table tmp_join'|db.execute &2>/dev/null #usuÅ tabelÄ tmp_streams jeżeli istnieje
####okreÅlenie regionu analizy
g.region rast=$class #ustaw region wzglÄdem pliku class
####### procedura wygenerowania punktów z mapy
# najpierw sprawdzamy, czy plik ma kategorie jeżeli nie koÅczymy
tp=`eval v.category -g input=$vector type=line option=report`>/dev/null
if [ -z $tp ]
then
echo "wektor nie ma kategorii. PrzewidujÄ problemy, wiÄc koÅczÄ"
exit 1
fi
v.to.points -n input=$vector output=tmp_point type=point,line llayer=1 dmax=100
v.db.addcol map=tmp_point layer=2 'columns=rzad INTEGER, magn INTEGER, link INTEGER, is_main INTEGER, zlewnia_elem INTEGER, z1 INTEGER, z2 INTEGER, z3 INTEGER, z4 INTEGER, z5 INTEGER, z6 INTEGER'
#probkowanie rastrow
v.what.rast vector=tmp_point raster=$links layer=2 column=link
v.what.rast vector=tmp_point raster=$strahler layer=2 column=rzad
v.what.rast vector=tmp_point raster=$shrevee layer=2 column=magn
v.what.rast vector=tmp_point raster=$main layer=2 column=is_main
echo 'zlewnia_elem'
v.what.rast vector=tmp_point raster=$zlewnia_elem layer=2 column=zlewnia_elem
v.what.rast vector=tmp_point raster=$z1 layer=2 column=z1
v.what.rast vector=tmp_point raster=$z2 layer=2 column=z2
v.what.rast vector=tmp_point raster=$z3 layer=2 column=z3
v.what.rast vector=tmp_point raster=$z4 layer=2 column=z4
v.what.rast vector=tmp_point raster=$z5 layer=2 column=z5
v.what.rast vector=tmp_point raster=$z6 layer=2 column=z6
#tworzenie tabeli zawierajÄ
cej uÅrednione parametry morfometryczne strumieni
v.to.points -i input=$vector output=$vertex type=line dmax=20
v.db.addcol map=$vertex layer=2 'columns=elev REAL, elev2main REAL, elev2stream REAL, slope REAL, planc REAL, profc REAL, maxic REAL, diff5 REAL, diff9 REAL, diff15 REAL'
#probkowanie dużej tabeli. Tabela vertex zostaje zachowana ze wzglÄdu na przydatnoÅÄ do innych celów
v.what.rast vector=$vertex raster=$elev layer=2 column=elev
v.what.rast vector=$vertex raster=$elev2main layer=2 column=elev2main
v.what.rast vector=$vertex raster=$slope layer=2 column=slope
v.what.rast vector=$vertex raster=$planc layer=2 column=planc
v.what.rast vector=$vertex raster=$profc layer=2 column=profc
v.what.rast vector=$vertex raster=$maxic layer=2 column=maxic
v.what.rast vector=$vertex raster=$diff5 layer=2 column=diff5
v.what.rast vector=$vertex raster=$diff9 layer=2 column=diff9
v.what.rast vector=$vertex raster=$diff15 layer=2 column=diff15
echo 'CREATE TABLE tmp_streams_param AS SELECT lcat AS lcat, avg(elev) AS rzedna, avg(elev2main) AS elev2mean, avg(slope) AS slope, avg(planc) AS planc, avg(profc) AS profc, avg(maxic) AS maxic, avg(diff5) AS diff5, avg(diff9) AS diff9, avg(diff15) AS diff15 FROM '$vertex'_2 GROUP BY lcat'|db.execute
#utworzenie tabeli zawierajÄ
cej STAHLER STEAM ORDER oraz LINK wektora (tylko postgreSQL lub SQLite!)
echo 'CREATE TABLE tmp_streams AS SELECT p0.lcat as cat, p0.rzad, p0.magn as magn, p0.link as link, p1.link AS link_to, p0.is_main as main, p1.is_main as contrib, p0.zlewnia_elem as zlewnia_elem, p0.z1 AS z1, p0.z2 AS z2, p0.z3 AS z3, p0.z4 AS z4, p0.z5 AS z5, p0.z6 AS z6 FROM (SELECT lcat, link, is_main FROM tmp_point_2 WHERE along>0) p1 INNER JOIN (SELECT lcat, link, rzad, magn, is_main, zlewnia_elem, z1, z2, z3, z4, z5, z6 FROM tmp_point_2 WHERE along=0) p0 ON p0.lcat=p1.lcat'|db.execute
#PolÄ
czenie tabel
echo 'CREATE TABLE tmp_join AS SELECT * FROM tmp_streams c INNER JOIN tmp_streams_param p ON c.cat=p.lcat'|db.execute
g.copy vect=$vector,tmp_join
v.db.connect -o map=tmp_join table=tmp_join driver=pg database='rzeki_mgr' key=cat layer=1
v.db.addcol map=tmp_join layer=1 'columns=dlugosc REAL'
v.to.db map=tmp_join type=line option=length columns=dlugosc
g.copy vect=tmp_join,$cieki
echo 'DROP table tmp_join'|db.execute &2>/dev/null #usuÅ tabelÄ tmp_join jeżeli istnieje
