[GRASS-user] v.overlay + script
Giovanni Pasini
jynxtor at gmail.com
Thu Jul 23 11:31:49 EDT 2009
Hello everybody,
I have a question about v.overlay, (... sorry about my english)
Some vect:
from=railway (polygon)
to=streets (polygon)
sn=3 (snap thresold in meters)
with railway that run next to a street from streets layer whith some
little overlaps and gaps
(see:
http://www.petaimg.com/u376/492fig1.png
http://www.petaimg.com/u201/464fig2.png
http://www.petaimg.com/u315/660fig3.png
I have add railway some vertices (v.edit tool=vertexadd) -> ${from}_mod
and then I make:
v.edit ${from}_s tool=create --o
v.out.ascii ${from}_mod format=standard | v.edit ${from}_s tool=add
th=-1,$sn,0 bgmap=temp_${from}_${to} snap=vertex --verbose #where
temp_${from}_${to} is a vector of points (see script at bottom of the
message and http://www.petaimg.com/u318/606fig4.png).
Now I have ${from}_s only slighty different from $from, now it is more
close to $to (see http://www.petaimg.com/u253/302fig7.png and
http://www.petaimg.com/u97/454fig8.png)
I want overlay the two maps:
v.overlay ain=${from}_s bin=${to} out=${from}_s_${to} op=or -> give me
http://www.petaimg.com/u447/665fig5.png
Some boundary in the south are deleted?? why?
while:
v.overlay ain=${from}_mod bin=${to} out=${from}_mod_${to} op=or -> give
me http://www.petaimg.com/u12/386fig6.png
is OK!?
I look for some topology problem in ${from}_s but it appear ok! How can
I solve this problem?
I can post the vector files (as ascii), I'm running GRASS 6.4.0RC4 on a
debian testing box.
Can you give some suggestion about snap_01.sh script?
Thanks in advance for the help,
giovanni
snap_01.sh
#!/bin/bash
#snap_01.sh
from=$1
to=$2
sn=$3 #snap thresold in meters
#1) $from's points near vertex/node to $to
echo "Extraction nodes and vertex from $from, patch and v.category >>
${from}_tos_2"
v.to.points -n in=$from out=${from}_n
v.to.points -v in=$from out=${from}_v
v.patch in=${from}_n,${from}_v out=${from}_tos_1
v.category in=${from}_tos_1 out=${from}_tos_2 opt=add lay=3
g.remove vect=${from}_n,${from}_v,${from}_tos_1
echo "Points' list on $to >> temp_${from}_${to}.txt"
v.distance -p from=${from}_tos_2 from_type=point from_lay=3 to=$to
to_type=boundary up=to_x,to_y col=x,y dmax=$sn --o --q | grep -v null >
temp_${from}_${to}.txt #from_cat|x|y
g.remove vect=${from}_tos_2
#2) $to's boundary vertex/node
echo "Extraction nodes and vertex from $to, patch and v.category >>
${to}_tos_2"
v.to.points -n in=$to out=${to}_n
v.to.points -v in=$to out=${to}_v
v.patch in=${to}_n,${to}_v out=${to}_tos_1
v.category in=${to}_tos_1 out=${to}_tos_2 opt=add lay=3
echo "cat to temp_${from}_${to}.txt"
v.to.db map=${to}_tos_2 opt=coor -p lay=3 --q >> temp_${from}_${to}.txt
g.remove vect=${to}_n,${to}_v,${to}_tos_1
cut -d "|" -f2,3 temp_${from}_${to}.txt | v.in.ascii
out=temp_${from}_${to} skip=1 cat=0
g.copy vect=$from,${from}_mod
echo "vertexadd to ${from}_mod, log_vertexadd_${from}_mod.txt"
echo "start log: -----------------------------------------" >
for coord in `v.distance --q -p from=${to}_tos_2 from_type=point
from_lay=3 to=${from}_mod to_type=boundary up=to_x,to_y col=x,y dmax=$sn
| cut -d"|" -f2,3 | grep -v -e 'x' -e 'null' | tr "|" "," `; do v.edit
map=${from}_mod tool=vertexadd th=0.01 coords=$coord >>
log_vertexadd_${from}_mod.txt 2>&1; done
echo "Makig of ${from}_s and snap to temp_${from}_${to}"
time v.out.ascii ${from}_mod format=standard | v.edit ${from}_s tool=add
g.remove vect=${to}_tos_2
#end
