[GRASS-user] Building topologically correct stream network
Jarek Jasiewicz jarekj at amu.edu.pl
Thu Jul 23 11:45:42 EDT 2009
Markus Metz pisze:
> Margherita Di Leo wrote:
>> Hi all
>> Hi Markus,
>> thanks for your answer. I found that the problem is in the topology
>> of the river network. I think that v.strahler produces many '0'
>> because it finds many little 'circles' in the stream vector. I tried
>> to produce the stream network both with r.watershed -> r.to.vect and
>> with r.strahler.sh -> r.to.vect: the results obtained in both ways
>> are very similar. Is there a way to eliminate these circles, not by
>> hand ?
> r.strahler.sh tries to if I understand the script right, but there
> must be side effects: what were parallel streams with a ladder may be
> merged into one stream.
> Maybe a new module to extract both raster and vector stream networks
> from any flow accumulation map would indeed be useful.
Yes, r.to.vect will almost never give correct directional network. It
require, as Marcus pointed different approach. r.flow ma be a good
starting point to create new module
Jarek
> Markus M
>>>> I'm sorry but the procedure that I proposed does not produce good
>>>> results. In fact the ascii file produced by v.strahler has very
>>>> strange orders, and also many 0 (that does not have sense in
>>>> strahler order!). I think the problem is generated in finding the
>>>> outlets
>>> Outlet points are where stream is not null and drainage direction is
>>> negative, e.g.
>>> r.mapcalc "outlet_points = if(!isnull(streams) && drainage < 0,
>>> streams, null())"
>>> That would give you outlet points whose cell value is the stream
>>> segment number leading to the outlet point.
>>>> and/or confluences.
>>> All nodes of the stream vector, excluding outlet points?
>>> Markus M
>>>> Waiting for the response of the List (please)..
>>>> margherita
>>>> Jarek Jasiewicz wrote:
>>>>> Hi
>>>>> maybe this will help:
>>>>> http://gis.vsb.cz/GIS_Ostrava/GIS_Ova_2009/sbornik/Lists/Papers/060.pdf
>>>>> it require another gis program but gives great results!
>>>>> Jarek
>>>>> Margherita Di Leo pisze:
>>>>>> Hi Stephen,
>>>>>> I actually am fighting against almost the same problem, so let's
>>>>>> do it together :)
>>>>>> I found that r.strahler.sh works well to delineate streams and
>>>>>> correct topology, (I use a treshold of 1km^2, it works well but
>>>>>> don't ask me why :) ), but (in my little experience) does not
>>>>>> work to order streams, so I must run v.strahler after r.strahler.sh.
>>>>>> I know it's a very small hint but hope this helps.
>>>>>> Best
>>>>>> margherita
>>>>>> I have a low relief area in the costal plain of georgia that I am
>>>>>> trying to produce a topologically correct stream network. There
>>>>>> are many breaks in the flow accumulation grid and I would like to
>>>>>> delineate the streams and "correct" the topology after r.thin and
>>>>>> r.to.vect have been preformed so that I can then use v.strahler
>>>>>> to order the streams. Thanks for any help and I will provide and
>>>>>> data that would be helpful. thanks,
>>>>>> -- Stephen Sefick Let's not spend our time and resources thinking
>>>>>> about things that are so little or so large that all they really
>>>>>> do for us is puff us up and make us feel like gods. We are
>>>>>> mammals, and have not exhausted the annoying little problems of
>>>>>> being mammals. -K. Mullis
