[GRASS-user] r.watershed crashing grass.
stephen sefick ssefick at gmail.com
Fri Jul 24 22:51:22 EDT 2009
I will look tomorrow, but I think it was about 1000x1000.
hth
Stephen Sefick
On Fri, Jul 24, 2009 at 9:47 PM, Milton Cezar
Ribeiro<miltinho.astronauta at gmail.com> wrote:
> Hi Stephen,
> Thanks for your reply.
> I thank the disk space is not problem because I still have 100Gb free.
> What was the dimension (row and columns) that you got success?!
> May be 7200x7200 is to large.  (?)
> Cheers
> milton
> 2009/7/24 stephen sefick <ssefick at gmail.com>
>> Do you have enough hard disk space?  I have had a problem running
>> r.watershed on very large datasets (my computer is much more modest).
>> I have had luck resampling the data to a larger resolution and then
>> running r.watershed.  r.watershed crashes at 10m res but will run just
>> fine at 50m.  1GB RAM.
>> Stephen Sefick
>> On Fri, Jul 24, 2009 at 5:57 PM, Milton Cezar
>> > Dear all,
>> > I am trying run a r.watershed command with one 7200x7200 DEM map.
>> > But after one day running, the system crash without finish the output
>> > generation.
>> > Please, see below (2 warnings before crash).
>> > By the way I am running grass 6.4.0 SVN (rc4?) under Msys/Vista
>> > on a 6Gb/64 bits machine.
>> > Thanks for the help,
>> > milton
>> > GRASS 6.4.0svn (newLocation):c:/Users/famiglia > g.region -p
>> > projection: 0 (x,y)
>> > zone:       0
>> > north:      -23.99986111
>> > south:      -26.00013889
>> > west:       -49.00013889
>> > east:       -46.99986111
>> > nsres:      0.00027778
>> > ewres:      0.00027778
>> > rows:       7201
>> > cols:       7201
>> > cells:      51854401
>> > GRASS 6.4.0svn > g.region rast=FabioASTGTM_S2526W04948_dem
>> > GRASS 6.4.0svn > r.watershed.exe -m 4096
>> > elevation=FabioASTGTM_S2526W04948_dem
>> > stream=FabioASTGTM_S2526W04948_dem_rwatershed_stream_thres0100
>> > threshold=100
>> > --o
>> >  WARNING: Subprocess failed with exit code 255
>> > WARNING: category information for
>> >          [FabioASTGTM_S2526W04948_dem_rwatershed_stream_thres0100] in
>> >          [PERMANENT] missing or invalid
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
>> Stephen Sefick
>> Let's not spend our time and resources thinking about things that are
>> so little or so large that all they really do for us is puff us up and
>> make us feel like gods.  We are mammals, and have not exhausted the
>> annoying little problems of being mammals.
>>        -K. Mullis
Stephen Sefick
								-K. Mullis
