[GRASS-user] r.watershed crashing grass.
Markus Metz markus.metz.giswork at googlemail.com
Sat Jul 25 03:23:01 EDT 2009
Try to run it all in memory:
r.watershed.exe elevation=FabioASTGTM_S2526W04948_dem
stream=FabioASTGTM_S2526W04948_dem_rwatershed_stream_thres0100
threshold=100 --o
Should finish in a few minutes.
Where is this 4096 coming from in the original command? Should that be
memory=4096?
r.watershed.exe -m memory=4096 elevation=FabioASTGTM_S2526W04948_dem
threshold=100 --o
How far did it get? There are usually message like SECTION 1:, SECTION
2:, SECTION 3: etc.
Markus M
Milton Cezar Ribeiro wrote:
> Dear all,
> I am trying run a r.watershed command with one 7200x7200 DEM map.
> But after one day running, the system crash without finish the output
> generation.
> Please, see below (2 warnings before crash).
> By the way I am running grass 6.4.0 SVN (rc4?) under Msys/Vista
> on a 6Gb/64 bits machine.
> Thanks for the help,
> milton
> GRASS 6.4.0svn (newLocation):c:/Users/famiglia > g.region -p
> projection: 0 (x,y)
> zone:       0
> north:      -23.99986111
> south:      -26.00013889
> west:       -49.00013889
> east:       -46.99986111
> nsres:      0.00027778
> ewres:      0.00027778
> rows:       7201
> cols:       7201
> cells:      51854401
> GRASS 6.4.0svn > g.region rast=FabioASTGTM_S2526W04948_dem
> GRASS 6.4.0svn > r.watershed.exe -m 4096
> threshold=100 --o
>  WARNING: Subprocess failed with exit code 255
> WARNING: category information for
>          [FabioASTGTM_S2526W04948_dem_rwatershed_stream_thres0100] in
>          [PERMANENT] missing or invalid
