[GRASS-user] g.manual tries to run C:\Program Files\Internet
Exporer\iexplore (the 'L' is missing from 'Explorer')
Frank Bilki
fbilki at gmail.com
Sun Jul 26 02:35:10 EDT 2009
Hi Milton,
That worked! Thanks so much for the suggestion.
I experimented with combining the forward slashes and the full pathname with
spaces (e.g. C:/Program Files/Internet Explorer/iexplore) and that also
worked. So it seems the cause was using back-slashes instead of
forward-slashes.
I notice that the batch file contains a mixture of back- and
forward-slashes, e.g.:
set WINGISBASE=%OSGEO4W_ROOT%/apps/grass/grass-6.4.0svn
"%WINGISBASE%"\etc\init.bat %*
Is there a systematic rule for choosing which to use?
Cheers,
Frank
From: Milton Cezar Ribeiro [mailto:miltinho.astronauta at gmail.com]
Sent: Sunday, 26 July 2009 2:05 PM
To: Frank Bilki
Cc: grass-user at lists.osgeo.org; neteler.osgeo at gmail.com
Subject: Re: [GRASS-user] g.manual tries to run C:\Program Files\Internet
Hi Frank,
Try:
set GRASS_HTML_BROWSER=C:/Progra~1/Intern~1/iexplore
You can also cast opening the following file on your browser:
file:///C:/OSGeo4W/apps/grass/grass-6.4.0svn/docs/html/full_index.html
(change the version directory)
bests
milton
