[GRASS-user] r.watershed crashing grass.
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Sun Jul 26 03:30:47 EDT 2009
Hi Glynn
Just suppose I start Msys. Is there a way of i know if (1) my compiled
version of grass support 64bits? or (2) if my gcc etc support 64bits?
Thanks a million..
milton
2009/7/26 Glynn Clements <glynn at gclements.plus.com>
> Markus Neteler wrote:
> > > In fact I have a dell machine, with Vista 64bits that came with the
> machine.
> > > I compiled grass 64 svn using Msys. Is there a way of I know if my
> grass are
> > > running with 64bits? By the way, what I need to change to have sure
> that
> > > grass was compiled to 64bits?
> > Did you enable it?
> > --enable-64bit
> > for configure...
> That switch doesn't do anything on Windows. Or on Linux, for that
> matter. It is only used on (some versions of) AIX, HP/UX, Irix, and
> Solaris.
> If you want 64-bit Windows executables, you would need 64-bit versions
> of gcc and binutils.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090726/9d0e0558/attachment-0001.html
