[GRASS-user] announcement of strahler stream order analysis
Jarek Jasiewicz
jarekj at amu.edu.pl
Tue Jul 28 11:46:17 EDT 2009
try, I don't know I haven't LL location to test it
but it shoud work
program do not use any inforamtuon about units and units conversion
Jarek
Milton Cezar Ribeiro pisze:
> Hi Jarek
> Can use this on a LatLong mapset where my unit is not meters?
> Thanks for the effort!
> milton
> 2009/7/26 Jarek Jasiewicz <jarekj at amu.edu.pl <mailto:jarekj at amu.edu.pl>>
> Hi list!
> I just finish first version of new grass module r.stream. Module
> is regular Grass module, written in C an has no addational
> dependencies. It was compiled with GRASS65 devel downloaded in
> last two week. Source code you can find here:
> http://heretic.livenet.pl/heretic/r.stream.tar.gz
> Module compiles and seems to work. Analysis was tested only on one
> dataset.
> To compile it copy r.streams directory to your grassXX../raster/
> cd r.stream run make and make install
> What module calculate:
> - strahler stream order
> - shreeve stream magnitude
> - class of topological elements of drainage networks
> Module use r.watershed outputs: SDF flow direction and SDF stream
> network.
> Analysis of r.stream shall be run on same regions setings as
> r.watershed. If no, run g.region rast=your_dir_file first. For now
> module do not check if region and rasters are identical. It is
> planned to add in nearest feature. It also do not check if dirs
> and streams are SDF result. Threre are no addational description.
> It will be added after testing.
> It works only on cells data. Floating points data are not allowed
> (and have no sense).
> Module is quite fast. 3000 x3000 cells all three analysis runs no
> more than 30 s. on AMD 3800 2GB, Ubuntu 8.04
> Module is part of comprehensive project which will add full Horton
> analysis and some addational terrrains analysis to Grass. More
> details in the feature. Any cooperation is welcome. The next
> module I plan is directional vectorisation of stream network.
> For now module is available only form web address pointed below.
> After testing and removing critical errors it will be added to
> grass add-ons (or maybe to main branch?).
> Any coments, improvements and critics is very welcome.
> More advanced Grass developers: Please check my code. Its funny,
> but I don't know C.
> General code is based on GRASS r.topindex module (by Keith Beven
> and Huidae Cho, strongly modified)
> Strahler stream order algorithm from Saga GIS (by Victor Olaya,
> modified)
> Shreeve stream magnitude and class of topological network are my
> own ideas
> Test and enjoy.
> Jarek Jasiewicz
> Adam Mickiewicz University, Poznan
> Geoecology and Geoinformation Institute
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
