[GRASS-user] Vector from Raster Problems (r.stream)
Annalisa Minelli
annagrass6 at gmail.com
Tue Jul 28 12:40:40 EDT 2009
Yes, I found this problems too for using v.strahler..
so we tried to solve with r.strahler.. but we still have some problems for
low values of (r.wateshed) threshold..
but maybe Jarek has a better way with this new approach to the problem..
just "no dependencies" sounds good..
so we wait for good news!
Annalisa
2009/7/28 Jarek Jasiewicz <jarekj at amu.edu.pl>
> stephen sefick pisze:
>> I have compiled and used Jarek's stream order script and the results
>> look to be satisfactory- good job!.
> You use windows as I remember, isn't it It is very important for me if
> program also work on windows. Please send me aslo feeback about time of
> analysis and size of maps
>> I am having a hard time creating
>> vectors from this raster representation. r.thin -> r.to.vect creates
>> lots of erroneous squares that I believe are there as an artifact of
>> the larger stream networks.
> It is problem that no streams are marked as 0 (for now, it will be fixed to
> null). For now try to
> convert 0 to null with mapcalc formula: neworder=if(order=0,null(),order)
> and try again.
>> The lower order (smaller) streams look
>> fine, but when you start getting to the higher order streams +5 I
>> think the r.thin algorithm may have problems delineating a stream.
> Is
>> there a way around this? I would be happy with a line that ran
>> through the middle of the stream for now. Some trick converting to
>> points and then to lines? Or something along those lines. Is there a
>> way to connect centroids? I have made an area map of the streams
>> raster- can I connect the areas together? Thanks for any help.
>> thanks,
> I just work on another module which will be convert stream netowork to
> correct vector stream network (in most cases r.to.vect do not it well) i
> thing it is metter of next week.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090728/11641eb9/attachment.html
