[GRASS-user] GRASS 7.0 svn location/map creation using console
    Glynn Clements
    glynn at gclements.plus.com
    Thu Jul 30 14:13:47 EDT 2009
[CC to grass-dev]
Enrico Gallo wrote:
> I can  use g.proj and g.mapset only inside GRASS environment,
> but if  I have non correct location I cannot enter in GRASS 7.x from
> console, using -text flag, of course
Without the GUI, you currently have to create a new location manually,
e.g.:
olddbase=`g.gisenv get=GISDBASE`
g.gisenv set=GISDBASE=/path/to/database
g.proj -c location=newlocation ...
g.gisenv set=GISDBASE=$olddbase
g.mapset -c gisdbase=/path/to/database location=newlocation mapset=newmapset
g.mapset gisdbase=/path/to/database location=newlocation mapset=newmapset
g.region -d
Note that GRASS 7 includes a dummy location at $GISDBASE/demolocation;
this can be used to get into GRASS, provided that you're the owner of
the GRASS installation (probably root).
For developers:
1. init.{sh,py} need an option to create a new database/location/mapset
without using the GUI.
2. g.proj should have a database= option so that -c can create a new
database along with the location.
3. g.mapset complains if the current database/location/mapset aren't
valid; it should probably be changed to use G_no_gisinit() to handle
this.
