[GRASS-user] which points in vector A fall in areas of vector B?
Moritz Lennert mlennert at club.worldonline.be
Fri Jul 31 04:13:28 EDT 2009
On 30/07/09 20:22, Corrado Topi wrote:
> Dear friends,
> I need to discover which points out of vector A fall within the area covered
> by vector B (areas). How do I do that? I tried v.select and v.overlay, but
> without success.
v.select should do what you want (well unless you use grass6.5+ compiled
with GEOS you only get the overlay operator, but for points in areas
this is almost equal to within), so you would need to be more specific
about how you used it and what "without success" means (error ?).
Moritz
