[GRASS-user] Re: error importing postgresql db
    Seb
    spluque at gmail.com
    Mon Jun  1 12:28:02 EDT 2009
On Mon, 1 Jun 2009 07:40:28 +0200,
Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Jun 1, 2009 at 1:50 AM, Seb <spluque at gmail.com> wrote:
>> On Mon, 01 Jun 2009 00:54:05 +0200,
>> Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de> wrote:
>> Seb:
>>> Not sure if this is a conflict with SQL commands, but you could try
>>> to _feed_ new names for your columns by using the "cname=" paramater
>>> of "v.in.ogr" and see what happens?
>> I tried that but the problem remains.  It seems as if there's
>> problems importing such datetime columns.  Thanks.
> Can you please post cmd line and error?
Here's what I get from v.in.db with a view that has a Postgis geometry
column where the reprojection to the local GRASS location was done
directly.  This gives the same error message as what I saw with
v.in.ogr, even after changing the column names with the 'cnames'
argument:
---<--------------------cut here---------------start------------------->---
v.in.db driver=pg database="dbname=locations,port=5433" \
        table=locs x='x(pts_aea)' y='y(pts_aea)' key=locid out=test --o
> WARNING: Vector map <test> already exists and will be overwritten
WARNING: pg driver: PostGIS column 'pts_ll', type 'geometry' will not be
         converted
WARNING: pg driver: PostGIS column 'pts_aea', type 'geometry' will not be
         converted
Writing features...
Copying attributes...
         converted
         converted
WARNING: Type TEXT converted to 'VARCHAR(250)'
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected NAME processing 'datetime'
in statement:
create table test ( sample_id varchar(12), project varchar(500), species varchar(300), sex varchar(250), flipper_tag integer, date_time_deployed datetime, claw_marks integer, mass double precision, body_length double precision, girth double precision, fat_depth double precision, locid integer, prognum varchar(10), date_time datetime, class varchar(3), lon double precision, lat double precision )
Cannot create table
WARNING: Unable to create table <Ðg¹>
WARNING: Unable to copy table
Building topology for vector map <test>...
Registering primitives...
1311 primitives registered
1311 vertices registered
Building areas...
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 976
Number of primitives: 1311
Number of points: 1311
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
v.in.db complete. 1311 points written to vector map.
---<--------------------cut here---------------end--------------------->---
Seb
