[GRASS-user] Deleting vertices based on a list of points
    Dwight Needels
    needels at translucida.com
    Tue Jun  2 14:50:32 EDT 2009
Hi all,
I have two vectors: Vector A has lines and Vector B has points that
share the same coordinates as a subset of the vertices in the lines. I
would like to delete all of the vertices/nodes in Vector A that lie
directly underneath the points in Vector B (or perhaps lie within a
threshold).
I suspect that v.edit tool=vertexdel can do this, but I cannot figure
out how to pass the coordinates of a set of points from Vector B to
v.edit to be used to select vertices in Vector A for deletion. Could
somebody give me a hand with this (or tell me it is not possible)?
Thanks, -Dwight
