[GRASS-user] Discrepancies between Location Wizard and Projection Values (WXPython vs TCLTK)
Paul Kelly paul-grass at stjohnspoint.co.uk
Fri Jun 5 03:26:01 EDT 2009
On Thu, 4 Jun 2009, Casey Vandenberg wrote:
> Hi everyone,
> I have been noticing some discrepancies in the PROJ_INFO files that are
> created using Grass6.4 RC4 between the projection values option in the tcltk
> interface and the location wizard option using the wxpython interface.
> For example, inputting the projection info:
> Coordinate System=UTM
> Datum=Nad27 - T04 (Transformation Parameters for Alaska)
> Ellipse: Clark66
> Zone=8
> I get the following PROJ_INFO files created.
> tcltk interface results:
> datum: nad27
> nadgrids: alaska
> proj: utm
> ellps: clark66
> a: 6378206.4000000004
> es: 0.0067686580
> f: 294.9786982000
> zone: 8
> wxpython results:
> name: Universe Transverse Mercator
> proj: utm
> ellps: clark66
> zone: 8
> no_defs: defined
They are exactly equivalent except that the wxpython one is missing the
datum information (adding the line "nadgrids: alaska" would fix that). So
the Tcl/Tk one is actually correct.
Paul
