[GRASS-user] no nulls outside project map area
William Kyngesburye
woklist at kyngchaos.com
Fri Jun 5 20:10:20 EDT 2009
I'm an idiot. It was the r.mapcalc in my script that wasn't taking
nulls into account.
On Jun 5, 2009, at 3:52 PM, William Kyngesburye wrote:
> Ugh - tried it with GRASS 6.4 and I get the nulls. Looks like a
> GRASS 6.5 bug.
> On Jun 5, 2009, at 3:43 PM, William Kyngesburye wrote:
>> I started with a tiff image, in Albers projection. Imported in a
>> new location in GRASS - the tiff region is rectangular with no
>> nulls in the region, so the GRASS region follows the tiff region
>> exactly.
>> Then I projected to a latlong location. The tiff is off to one
>> side of the central meridian, so the projected image appears
>> rotated and stretched, as expected:
>> <unprojected.png>
>> But the the triangular areas outside the original tiff region are
>> white, not null. My latlong region is larger than the image - I'm
>> going to merge multiple tiled and overlapping tiffs - and there are
>> nulls outside the extents of the projected area of the image.
>> Is this expected behavior? I usually go from latlong to projected
>> location, and the source latlong region is larger than the
>> projected region so I don't see this.
>> GRASS 6.5svn
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
