[GRASS-user] GRASS Extensions Manager -- compiling difficulties
Hamish hamish_b at yahoo.com
Sat Jun 6 05:07:59 EDT 2009
sela wrote:
> Trying to use the gem6 command, which has now emerged in the /gem-1.03
> folder, gives me the answer: bash: gem6: command not found
is the gem6 program somewhere in your PATH setting and set to be executable?
(chmod u+x)  does it exist anywhere?
in newer versions of GRASS the gem6 program that comes as part of the
program has been renamed gem64, gem65, and gem70. this way you can have
multiple versions of grass installed at once. Look to see if there's a
program of that name which has come installed with the main GRASS package.
Hamish
