[GRASS-user] GRASS Extensions Manager -- compiling difficulties
    sela
    stefansylla at gmx.de
    Mon Jun  8 04:51:45 EDT 2009
Sorry Markus,
I put wrong information into the forum, but of course I have only one path
to the grass directory which is /usr/lib/grass64 and I used only that path
when performing the make-command within the folder of the AddOn-package:
make MODULE_TOPDIR=/usr/lib/grass64/
...error messages....
make MODULE_TOPDIR=/usr/lib/grass64/ install
So, unfortunately, I still do not have a clue about these compiling
problems.
best regards
sela
Markus Neteler wrote:
> On Sat, Jun 6, 2009 at 7:01 PM, sela<stefansylla at gmx.de> wrote:
>> Dear all, thanks a lot for your replies so far.
>> To Markus:
>> As you said:
>> cd r.dn2ref.ast/
>> make MODULE_TOPDIR=/usr/local/grass-6.4.0svn
>> make MODULE_TOPDIR=/usr/local/grass-6.4.0svn install
>> I adjusted this to my local path:
>> make MODULE_TOPDIR=/usr/local/grass64 install
>> (is this really the path to the installation? Sorry, but I am quite new
>> to
>> linux)
> One of you path will be wrong - both need to be identical of
> course (guess that's why you got an error then).
> You can check with a file manager or "ls" to see if GRASS
> is in that directory.
> Best
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/GRASS-Extensions-Manager----compiling-difficulties-tp3034620p3041897.html
Sent from the Grass - Users mailing list archive at Nabble.com.
