[GRASS-user] easy question.
Tue Jun 9 12:36:13 EDT 2009
achim wrote:
> I have a vector layer with category numbers with very very high numbers.
> Thats not very useful for further work. Now I want to change the cats to
> an ascending order (1,2,3,...,n).
> Is that possible in an easy way? Or even if there is a complicated one
> it would be great.
r.reclass can create a reclass map. You can generate the reclass rules
using r.category and awk, e.g.:
r.category oldmap | awk '{print $1,"=",NR}' | r.reclass in=oldmap out=newmap
