[GRASS-user] RE:grass confignation
Markus Neteler
neteler at osgeo.org
Tue Jun 9 15:00:06 EDT 2009
On Tue, Jun 9, 2009 at 9:36 AM, maven apache<apachemaven0 at gmail.com> wrote:
> In fact I have create two folder nlocation and nmapset in the hiberarchy of
> (nlocation/nmapset),then I start the grass with the gui ,I got the error
> messgae that I am mot clear?....
Please (re)post the error.
> 1) I want to know the relation of the grassrc file and the contere location
> or mapset ? Which should be created frist?
The grassrc is created by GRASS.
> 2) If I do my process in the gui ,then should I do the g.region process?
You can control g.region either from command line of through the GUI.
> 3) Some data which can be displayed in the grass gui can not exported
> perfectly,most of them contains only black blank after exproted.....
> Thanks!
If you speak about raster maps then first run
g.region rast=yourmap
then export. Otherwise the current region part is exported which
does not necessarily match the map.
Markus
