[GRASS-user] what is requried when import data to grass?
maven apache
apachemaven0 at gmail.com
Thu Jun 11 02:48:51 EDT 2009
When import some raster data to grass,I use the following cmd:1) g.region -d
2) r.in.gdal input=D:/test.TIF output=testTT --overwrite
I got the error message as following:
Projection of dataset does not appear to match current location.
Location PROJ_INFO is:
datum: nad27
nadgrids: conus
proj: utm
ellps: clark66
a: 6378206.4000000004
es: 0.0067686580
f: 294.9786982000
zone: 13
Import dataset PROJ_INFO is:
cellhd.proj = 0 (unreferenced/unknown)
3) change the cmd to " r.in.gdal -o input=D:/test.TIF output=testTT
--overwrite " I know this override the projection,however I am not sure the
potential effect to the data.
Now the tiff is imported,and I got testTT.bule testTT.red testTT.green, then
I open them can only see blank. So I wonder it is caused by the projection
or location,I use the spanish data as the default location , and I tried to
create new location and mapset but never success...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090611/9e291ff0/attachment.html
