[GRASS-user] r.terraflow.short no output, failed
Falk Grossmann
fgrossmann at gmail.com
Thu Jun 11 04:34:03 EDT 2009
Dear Grass users,
I am having some problems getting something useful out of r.terraflow.short.
I have a fairly large rasta (Data type CELL, rows: 12,500 columns: 6,250
total: 78125000). My final objective is to get a watershed basin limits and
river network. Since the rasta is large and in integer for I have tried
using r.terraflow.short. However the command finished in 0 sec and no
outputs are generated. The message is as follows:
stats.out: File exists
STREAM temporary files in /var/tmp (THESE INTERMEDIATE
STREAMS WILL NOT BE DELETED IN CASE OF ABNORMAL TERMINATION
OF THE PROGRAM. TO SAVE SPACE PLEASE DELETE THESE FILES
MANUALLY!)
file stats.out exists - renaming.*
when changing the name of the stats.out file I get the following:
*r.terraflow.short -s --overwrite --verbose
elevation=431112 at Imatongfilled=1fld direction=1dir swatershed=1snk
accumulation=1acc tci=1tci
memory=100 stats=3stats.out*
cell 431112 header compatible with region header
Elevation stored as SHORT (2B)
Region size is 12500 x 6250
MANUALLY!)
file 3stats.out exists - renaming.
ami_single_temp_name: mkstemp failed: : No such file or
directory
Assertion failed: 0, file ami_stream.cc, line 75
This application has requested the Runtime to terminate it
in an unusual way.
Please contact the application's support team for more
information.
SFD (D8) flow direction
D8CUT=999999986991104.000000
Memory size: 100.00M (104857600) bytes
Memory manager registering memory in MM_WARN_ON_MEMORY_EXCEEDED mode.
I have no idea what those two failed indicatores refere to...
Am I missing something here? Any tips or help would be great!
Thanks,
Falk
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090611/936b8d50/attachment.html
