[GRASS-user] what is requried when import data to grass?
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Thu Jun 11 06:39:45 EDT 2009
maven:
> And I know the reason of the problem now.
Which is?
> However as what you said,I should create a new location and mapset if
> necessary,it does not work.
> I create two folders nLocation/nmapset and create a wind file in the
> nmapset dir, however when I run the grass gui,I also can not seclect
> the new location to enter.
Sorry, I never create manually those directories and the WIND file. I
always use the "recommended" way, that is through GRASS.
Read _A)_ or/ and _B)_ in:
http://grass.osgeo.org/grass64/manuals/html64_user/helptext.html
> It throw the error message:the selection location [nlocation ]is not
> valide. Is the procedure I create the new location is wrong? I
> followed the maual
Which manual?
Nikos
